Brief Description: left brake assbly and wheel pant
At last I received the brake mount weldment from Vans for the left side. It was 9 days from my call to the USPS delivering. (I still don't have the engine mount bolts from Aircraft Spruce ordered and shipped the same day.)
The left brake assembly and wheel are on. I am in the process of fitting the left wheel pant.
Well, the bolts arrived today 10 days after ordering thanks to First Class Mail. At least I got them. Taking a break from the wheel pant, I started the install of the motor mount and front gear assembly. After drilling and bolting the top right, I found the top left was 3/8" off the hole location. Using a series of clamps, I pulled the mount into position and drilled and bolted the second hole. The other 4 holes line up nicely along the bottom and present no issues drilling and bolting
Completed mounting the left pant. A long process of aligning, drilling, more aligning, more drilling. Once everything is in place the mounting points needed to be glassed for strength and filled in with flox.
