It was time to get back to the engine baffling and finish up adding the fabric. Not difficult, bur time consuming. I made a pattern and cut the material leaving a 2 inch overlap. I think it is excessive since the cowl clearance is ½ inch, but seems to be about what people are leaving. There are several areas where the material doesn’t lay flat against the cowling. I think with air pressure and heat from the engine that will resolve itself when I get flying.
