I ran all of the plug wires. To get the correct wire length, I had to install all of the spark plugs. This involved removing the desiccators and lower plug caps, draining the preservative oil out and installing the automotive plug adaptors, then spark plugs.
I found out the hard way I should have had the wire separators and routing guides handy when I cut the wires to length. At $3.25 a foot I will be replacing a few wires that ended up less than an inch short compromising the routing in one way or another.
I have been making an extra effort to keep the plug wire routing separate from the sensor wires. I used automotive clips to keep things tidy.
The fancy pants crimper purchased a few weeks ago works extremely well to both strip and do both crimps. Adding the caps took a little mouth moisture (spit) to get them to slide on. Very tight fit.
