Before I run the wiring from all of the sensors and spend time on a bracket for the Prop Control, I decided to install the baffles to make sure there was no conflict.
Once I completed all of the preassembly tasks, I worked up each side of the engine installing each section. Other than getting the rear baffle sections in place, this was quick and easy. However, installing the front baffle stopped me cold. The instructions say to set the front baffle ramp angles to the lower cowl inlets. I don't have the lower cowl installed. So, a stop to the baffle install until the cowl is installed. For that, all of the baffles installed to date come off.
