Leos Web Site
Date:  5-20-2018
Number of Hours:  6.00
Brief Description:  Aileron electric trim servo
The electric aileron trim installed into the right wing. The servo attaches by springs to the aileron pushrod at the most inboard access panel.
The assembly is built up out of components and riveted together. The servo position is centered, the springs are stretched out 6 inches in each direction, and clips are pull riveted onto the push/pull tube for the aileron.
trim servo installation
bracket to capture wire conduit
overall right wing wiring and pitot plumbing
