Leos Web Site
Date:  4-6-2018
Number of Hours:  10.00
Brief Description:  Left and right Ailerons
While I waited for the replacement rivets to arrive, I moved on to the ailerons.
Deburring components and cutting stiffeners takes a bit of time. Installing and drilling the aileron counterweight with several assembly and disassembly steps is also time consuming.
Both left and right are fully clecoed together the next step is to disassemble once again to do additional deburring and priming prior to final assembly.
The rivets came in today, so I can finish up the rear baffle on the right tank.
preassemblies of end ribs
pre assemblies of aileron skins
ready for final disassembly, deburr, prim and reassembly
