Brief Description: Preassembly of Flap Brackets, rib attach
Completed the preassembly of the flap brackets to the ribs for both wings Made the modifications to the two ribs for each wing as required. Preassembled and match drilled the preassembled ribs to the wings.
Next step is to deburr all of the ribs, insert the snap bushings and get them primed
I spent about another 8 hours today deburring all of the rear ribs and getting them primed. This is a long boring task that you just grit your teeth and get through it. I little bit of riveting and then all of the ribs get attached to the spar.
All of the attaching for both wings is complete. AN4 rivets, AN3 rivets and AN 3 bolts are all in and torqued (for the bolts)
bolted and riveted
finished spar with rear ribs
one and only selfie to prove it's me doing the build
