Leos Web Site
Date:  9-14-2017
Number of Hours:  6.00
Brief Description:  Mount Magnatometer, G5 and GMC307
I spent a little more money ordering the GMU11 (magnetometer), temp probe, configuration module, GMC307 (Autopilot head), G5 and back up battery. Four more pieces of avionics to go. Unfortunately, they are the big numbers PFD/MFD 5K each, GTN 650 10 K and the GTX45R 4K.
I installed the magnetometer shelf high in the empennage. Other RV-10s have the magnetometer there with little to no interference. The GMU11 is a new product from Garmin. A tiny little thing, about half the size of a deck of cards.
I installed the G5 and GMC307 auto pilot head in the center stack. While I was busy cutting holes, I cut out the aluminum for the GTN650.
If I buy the PFD next, I will be able to fire up all of the instrumentation and start the configuration process. Adding the MFD, GTN650 and GTX45R should be plug and play at that point
I am trying to decide if I want to install the forward and rear skin and bond the windows in before I lift the fuselage to install the gear.
GMU11 magnatometer mount
G5 and GMC207 auto pilot mounted and in place
view from the back
view from the back
