Brief Description: working back along the harness with integration
Continuing to work rearward on the wiring
I spliced in the leads from the trim controls to the roll and pitch auto pilot servos. I installed the pitch servo connector and completed the connection as the GSA28 pitch servo is already installed.
I terminated and secured the wiring to the ELT and the connecter for the GMU11.
I fabricated a small bracket for the baggage compartment door switch, mounted and completed the wiring there since it runs with the rear section of the harness. Now the rear overhead light comes on when the baggage door is opened. It will also act a reminder if the door is not properly secured.
Next up is fabricating a mounting bracket for the GTR 20 (remote radio), GTX45 (remote transponder) and GMU11 (magnetometer), then completing the connectors.
