I installed the pitch autopilot servo referring to the G3X installation manual for the drawings. No big deal except for the missing rod end from the otherwise very nice Garmin RV10 install kit. A call to Aircraft Spruce to confirm it should have been included and Garmin is drop shipping the missing part.
I had to disassemble the whole battery platform/elevator belcrank assembly to rivet in the center post of the rear baggage bulkhead. I left it un-riveted a long time ago to make crawling into the tail cone easier. I had to make a small steel cube to fit in and buck the lower rivets. I am not sure how someone would manage all of the crazy rivets without the tools/ability to make custom bucking bars as needed. I have at least a half dozen so far.
Next up here to finish is to wire the pitch trim leads to the GSA28 servo so the system will auto trim when engaged.
