Leos Web Site
RV-10
Fuel pump, key switch wiring
Ran wires from the fuel boost pump to the IP and battery buss.
Ran ignition wiring to starter key switch and ground
Ran master contactor swich wiring
Ran starter monitor wiring with 1K ohm resistor to VPX
Ran two VPX ground wires
starter relay wires
key switch
RV-10 Home
3762
Commentary
Cowel
Doors
Doors
419
Horz Stab and Elevat
Instrument Panel
57
419
Misc.
Overhead
Stabilizer/Elevator
Tailcone
Things learned
Vert Stab and Rudder
Vert Stab/Rudder
What have I learned
