Leos Web Site
Date:  4-2-2016
Number of Hours:  4.00
Brief Description:  added filler to rudder top faring
I have been cleaning up all of the details I skiped earlier on the rudder. In addition to adding the trim system, I am running the wiring for both trim and tail strobe. I'm not sure there is enough clearance between the vertical stab and rudder for what I am doing, so I will keep a backup in mind. All of the wire flex should be twist over about 7 inches.
I starte the slow process of filling and smothing the top faring. I also added nut plates to the bottom faring to allow future access to the tail strob if needed. I should finish up tomorrow.
filler added, needs sanding
nut plates on the bottom
