Leos Web Site
Date: 12-16-2015
Number of Hours: 0.00
Brief Description: More electrical archetecture
I'm still working on how I want to distribute the 10 switchableinputs from the VPX. Most of them will power multiple items so I will need to assign each of approximatly 27 VPX power pins creating virtual busses switchable by the ten switch inputs. If I have more than 27 individual powered devices (I have about 36) then I will need to add a few fuse blocks. I higher amperage power pin can then feed and be broken into smaller circuts. The E buss will also be a seperate fuse block.
I do not count any time spent studying on the build totals. That would add several hundred to the total. I am currently leaning towards Garmin two MFD system with two possible GPS choices:
Item Number Price Price Alt VP-X pro $1,995 $1,995 VP-X wire $150 $150 MFD 1 GDU460 10.6" $9,399 $9,399 MFD2 GDU460 10.6" inc inc ADAHR 1 GSU25 inc inc ADAHR 2 GSU25 $799 $799 Intercom GMA240 $845 $845 Auto pilot GMC307 $1,099 $1,099 Roll Servo GSA28 $750 $750 Pitch Servo GSA28 $750 $750 Radio 1, 25 kHz GTR200 $1,199 $1,199 Radio 2, 8.33 KHz GNC255 $4,495 in GPS Nav 1 in radio 2 in GPS ModeS Xponder out GTX23 $2,199 $2,199 Mode S in GDL 39R $799 $799 GPS Nav/Com GTN650 $11,400 GPS position only GPS20A $845 ARINC-429 GAD 29 $425 Video Input inc in each EFIS Backup Battery TCW ? ? Engine Monitor ModuleGEA24 inc inc Engine Sensor KitK00-00513-00 $1,250 $1,250 Foreflight Wi-Fi Adp AOA/Pitot heated Heat/Regul $449 $449
Total (excl VP-X) $24,878 $31,363
