Leos Web Site
Date:  12-7-2015
Brief Description:  elevator trim wire
I added sub D pins and sockets to the five elevator trim wires. Clear heat shrink over each joint to seal and heat shrink over the bundle. If I ever need to service the joint I can cut the heat shrink off and unplug each of the wires. This is the start of many wire runs.
This was my first time using the sub D crimper; I paid way too much for. I found that I had to be gentle when crimping or I pinched the wires right off in the process. A gentle squeeze and the crimp is solid.
On another note: pulling a string through the conduit with the shop vac with a little piece of shop (paper) towel tied on the end works perfectly. Tie and tape the wire on the string and pull it through. slick!
starting the wire runs
into the conduit
into the conduit
aating next steps
aating next steps
