Everything deburred and dimpled. Time to put things together.
I shimmed the front fuselage and the tailcone to match the joints and slowly slid the two pieces together. The dimpled panels were a little more difficult to bring together. After the two parts were together I riveted everything I could reach without a helper. Once the wife is feeling better she will help me buck the balance of the rivets.
Since I have the fuselage on a large build table I used a large rachet strap to rase the tail high enough to work on the bottom. I have the front sitting on the landing gear bracket stubs. With a few pieces of plywood the fuselage is stable enough to climb right in to work.
