Beyond Blue
Cozy MKIV
Chap 5: Fuselage Sid
1-3-2016
Step 6
Electric Channel Covers
BID cloth cut at 45 deg orientation and rough fit to form the electrical channel cover.
Shop temp 24 deg C and humidity 38 %.
30g resin and 11g hardner mixed with glass bubbles to make micro slurry.
Micro applied go the areas of foam where the BID cloth will be located.
BID cloth positioned to form channel cover and fine trimmed with the electric scissors.
30g resin and 11g hardner mixed to make epoxy.
Epoxy applied to the cloth and left to cure.
BID cloth fit to rough size
Micro Slurry applied to foam
Epoxy applied to BID cloth
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
