Beyond Blue
Cozy MKIV
Chap 5: Fuselage Sid
10-31-2015
Install 20.5" doublers
Shop temperature was 24 deg C and humidity was 42%.
The mating surfaces of the doublers and longersons were vacuumed.
Flox was mixed: 48g resin, 18g hardner, flox.
Two 20.5" long doublers were installed with flox at the aft end of the bottom longeron on both fuselage sides.
The longerons were held in place using clamps and nails in pre-drilled holes.
Excess epoxy was wiped away.
Nails to be removed prior to full cure.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
