Beyond Blue
Cozy MKIV
Chap 5: Fuselage Sid
6-13-2015
Chapter 5
Glassed Top Longerons
Shop temperature was 25 deg C and humidity was < 50%.
Four pieces of UND cloth were cut to size and rolled up for later use.
Flox was mixed and used to fill all the longeron corners.
Epoxy was applied to the wood and fiberglass surfaces where the UND cloth is to be applied.
Four layers of cloth were applied. The epoxy was applied using paint brushes.
Electric scissors were used to cut the cloth between the left and right fuselage sides.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
