Brief Description: Instrument Panel Foam Shaping - right side
The instrument panel foam is cut with a utility knife. Any small foam pieces that were accidentally broken off were easily repaired using 5min epoxy to attach the broken piece back on. Dry micro will be used later to repair any gauges etc. before glassing. The right side is now cutout.
