Brief Description: Remove excess epoxy from F22 foam
The F28, F22 doubler, and F22 foam bulkhead shapes were checked against the original M-4 drawings and confirmed to match.
Sanding blocks and sand paper were used to remove excess epoxy from the locations where the pieces were joined together. More effort required to remove the bumps of epoxy from the joints.
