Note: Right and Left are used with respect to the pilot sitting in the cockpit.
First the right side front top template was traced from drawing M-1 onto a sheet of paper using a pencil and ruler. The paper was then flipped over and the lines traced onto the back side which will be used for the left side front top template. The template was then cut using a precision knife.
Next the right side front bottom was traced from drawing M-2 onto a sheet of paper. The paper was then flipped over and the lines traced onto the back side which will be used for the left side front bottom template. The template was then cut with the knife.
