Beyond Blue
Cozy MKIV
Training & Setup
6-5-2010
Chapter 3
Book End - Make Depression for Photo
I found the centre of the diagonal block's surface and marked a 4 inch square.
With a wire brush, I roughed out a depression in the marked area.
The depression was smoothed out with a scrap piece of urethane foam. The corners of the depression were rounded.
Foam dust was vacuumed off the surfaces and the workshop was cleaned up in preparation for the next step which will be the second fiberglass layup.
Measure a 4 inch square
Rough out a depression
Smooth out the depression
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
