Beyond Blue
Cozy MKIV
Chapter 8
2-1-2020
Step 7
Install Transition Piece in Aft Heat Duct
Removed the peel ply and trimmed the excess fiberglass from the aft heat duct.
Drilled the seatbelt anchor holes out.
Sanded the aft heat duct then cut a hole in the top of the heat duct for the transition piece.
Workshop temperature 20 deg C and 41% humidity.
Mixed 12g resin and 4g hardner with some flox to make a thick batch of flox.
Flox'd the transition piece in place.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
