Beyond Blue
Cozy MKIV
Chapter 7: Fuselage
12-8-2018
Begin to contour the fuselage bottom corners
Cut three 1.5" thick blocks of wood and used wood screws to secure them together.
Created a paper template of the fuselage bottom corner shape and marked it onto the stack of blocks then used a band saw to cut it to shape.
Used a spray adhesive to secure sandpaper to the block.
Used an electric handsaw set to 45deg to start cutting one corner of the fuselage bottom.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
