Beyond Blue
Cozy MKIV
Chapter 7: Fuselage
11-4-2018
Step 1
Glass inside of scoop (aft section)
Sized paper (templates) to fit in the forward and aft scoop sections such that it will be 1/4" past the edges and >3/4" onto the bulkheads.
Cut 2 ply of BID cloth to the size of the templates.
Cut peel ply.
Workshop temperature 24deg C and humidity 52%.
Mixed a batch of epoxy using 152g resin and 58g hardner.
Wet out the 2-ply BID cloth for the aft scoop section.
Mixed a small batch of dry micro to fill any gaps in the aft scoop foam.
Mixed a batch of micro to cover the foam. Used epoxy to wet the bulkheads where they overlap with the cloth.
Placed the 2-ply BID cloth in the scoop and scissor trimmed the edges to ~1/4" past the edges.
Applied peel ply and more epoxy.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
