Beyond Blue
Date:  6-17-2018
Number of Hours:  3.50
Brief Description:  Started Chapter 7 Fuselage Exterior
Sanded the taped joints inside the fuselage.
Unpacked the shipment from Aircraft Spruce Canada to verify the inventory of supplies for work on the fuselage exterior.
Created the NACA Scoop template. A centreline was marked on the bottom of the fuselage and the template was positioned along the centreline then the outline of the scoop was traced on the fuselage bottom.
