Beyond Blue
Cozy MKIV
Chapter 6: Fuselage
12-2-2017
Glass the heat duct with 2 ply BID
Now to cover the outside of the heat duct with 2 plies of BID at 45 deg. top and sides.
Workshop temperature 25 deg C and humidity 48%.
Mixed a batch of epoxy with 146g resin and 56g hardner. Poured some of it in another cup and added micro bubbles.
Applied micro to the foam on the outside of the heat duct and applied epoxy to the existing glass surface on top of the heat duct.
Applied 2 plies of BID and covered the layup with Dacron. Curing.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
