Beyond Blue
Cozy MKIV
Chapter 6: Fuselage
10-6-2017
Flox heat duct together
Drilled holes through the fiberglass in the triangular braces for the aluminum tube.
Used 5 minute epoxy to put the top pieces of the heat duct together.
Clamped the 3 heat duct pieces to a 2 x 4 for trial fit before floxing. This took awhile to get the pieces oriented and aligned correctly.
Shop temperature set to 25 deg C and humidity 52%.
40g resign and 15.2g hardner mixed with flox and applied to the heat duct to secure the sides to the top. Curing in progress.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
