Beyond Blue
Cozy MKIV
Chapter 6: Fuselage
7-1-2017
6-ply UND landing gear bulkhead layup
Workshop temperature was 25 deg C and humidity 50%.
A batch of epoxy was made using 140g resin and 53g hardner.
The 6-ply of UND cloth was wet out with the epoxy.
Flox was mixed with the epoxy in a small cup then applied to the joint where the 6-ply will go.
Another batch of epoxy was made using 62g resin and 24g hardner.
The layups were cut out using electric scissors and positioned on the aft side of the forward landing gear bulkhead.
The layups were covered with peel ply and left to cure.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
