Beyond Blue
Cozy MKIV
Chapter 6: Fuselage
6-11-2017
Tape the joint between upper and lower bulkhead
Two plies of BID cloth were cut to 33" x 1.5" to tape the joint between the bottom and top half of the landing gear bulkhead.
Shop temperature was 25 deg C and humidity was 51%.
Peel ply was removed from yesterday's 3-ply UND layups.
Epoxy was mixed together with 98g resin and 38g hardner.
The 2-ply BID tape was wet out and epoxy was lightly brushed on the bulkhead where the tape is placed.
A small batch of flox was mixed and applied to the joint between the upper and lower bulkhead to ensure a smooth transition for the cloth.
The tape was applied to the bulkhead joint and covered with peel ply.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
