In preparation for glassing the fuselage sides, and subsequent work inside the fuselage, I've built a rotisserie so I can rotate the fuselage on its axis.
The fuselage will be supported by one bolt through the firewall (I will have to repair this hole later) and one bolt through F-22 where the nose gear tube will be installed later.
The bolt has to be installed at least two feet off the shop floor so that the fuselage sides can clear the floor.
I was able to fabricate the rotisserie from scrap wood that was used previously to aid in the fuselage fabrication and assembly.
