Brief Description: Carve out Fuel Sight Gauge Locations
Glued sandpaper onto wooden template blocks AA, BB, CC, and DD. These will be used to shape the top of the fuselage sides.
Located the fuel sight guage locations on both sides of the fuselage. By shining a small light in each corner from the inside of the fuselage it is easy to then identify and mark the corner locations on the outside of the fuselage.
Used a Dremel tool to remove the blue foam then peeled the tape off that was installed in Chapter 5.
