Marked the location on the left side of the fuselage where this will be inserted. This insert is positioned 32.75" aft of bulkhead F22 which places it abeam the front seat area. This insert will be used to support an aluminum step which is installed later.
Removed the foam from the area where the insert is installed.
Workshop temperature 23 deg C and humidity 38%. Mixed up some micro using 74g resin and 28g hardner.
Micro'd the insert in place and filled in some divets in the fuselage sides and bottoms with the extra micro.
