Beyond Blue
Cozy MKIV
NACA Scoop
Cut 2" thick blocks to size
Trim the horizontal birch plywood braces to accommodate the 3/8" PVC foam later.
Cut a block of 2" thick Urethane foam to fit on top of the plywood braces between the aft landing gear bulkhead and the firewall.
Vacuum.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
