Beyond Blue
Cozy MKIV
step 3
Taped floor to landing gear bulkhead corner
Removed the temporary board supporting the aft end of the floor then scraped the glue from the landing gear bulkhead.
Shop temperature 25 deg C and humidity 41%.
Cut 2 pieces of BID cloth 33" x 2".
Mixed a cup of epoxy using 112g resin and 42g hardner.
Wet out the 2-ply BID tape then applied epoxy to the corner of the landing gear and floor.
Mixed a batch of flox and applied it to the corner.
Cut out the BID tape and applied it to the corner and used a brush to stipple the tape.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
