Beyond Blue
Cozy MKIV
step 3
Permanent floor installation
Permanent Installation of the aircraft floor.
Shop temperature was 25 deg C and humidity 39%.
Several batches of medium stiff flox was mixed.
The flox was applied on all the mating surfaces: longerons, seatback, heat duct, and front bulkhead F22.
Shims were positioned and floxed.
Noah helped me lift the floor off the work table onto the fuselage.
The floor was positioned properly and then weights and clamps were used to hold it in place during cure.
Excess flox inside and out of the fuselage was wiped away.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
