Brief Description: Positioning & Fitting floor into fuselage assembly
Positioned floor in place.
Sanded and used the dremel tool to level the floor at the front where it mates with bulkhead F-22.
Hot glued a temporary block to the forward landing gear bulkhead 1/4” below the scoop cut out to support the fuselage floor while it cures in place. This positions the floor 1/8" above the cutout.
Weighed down the floor and clamped the sides to uncover areas needing shims.
