Brief Description: Fitting fuel valve and bracket in place
Weights were removed from the seatback brace.
The four port 3-way fuel valve was fastened to the aluminum bracket with two machine screws and two lug anchors. A drain fitting was inserted into the bottom port of the fuel valve.
The valve and bracket assembly was trial fit into position on the seatback brace.
