Brief Description: Cut glass for triangular brace spacers
Rounded the edges of the foam on the heat duct in preparation for glassing.
Drilled small holes through both triangular braces where the 5th spacer will go along the back and bevelled the spacers for better fit with this 5th spacer.
Vacummed the foam dust from the heat duct and the work table.
Cut 1 layer of BID cloth to size for each of the 5 spacers.
