Beyond Blue
Cozy MKIV
Tape inside corners lower firewall
Cut four 10" x 2" strips of BID cloth at 45 deg orientation.
Shop temperature was 25 deg C and humidity 48%.
46g resin was mixed with 18g hardner.
Wet out two sets of the strips (2-ply each) with the epoxy.
Wet the inside corners of the lower firewall with epoxy.
Poured some of the epoxy into a small paper cup and added flox to create a thick flox.
Flox applied to both inside corners of the lower firewall.
Corners taped and tape edges covered with Dacron and wet out with epoxy.
Curing in progress.
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
