Brief Description: Prepare outer surface and forms (right side)
Using the grinder I sharpened up a few of the chisels. The chisels were used to remove masonite that was stuck to the outer surface of the right fuselage side.
Next, any PVC foam that was stuck to the right side form was removed and glued back into the right fuselage side.
Any lumps of 5min epoxy on the right side form was removed.
