Brief Description: Cut remainder of masonite forms
1. I cut out the right side fuselage masonite form using an electric hand saw.
2. I used the right side to trace out the left side fuselage masonite form.
3. I cut out the left side fuselage masonite form with an electric hand saw.
4. Using the leftover masonite I cut out the additional pieces using the band saw. See figure 5 "ADD PIECE HERE".
Note: the construction plans called for fixing the wooden jigs to the work table at the start of chap 5 step 2. I decided to wait on that so I could use the worktable to measure out the masonite forms and foam pieces then I'll setup the jigs.
