Beyond Blue
Cozy MKIV
Chapter 4
Instrument Panel Forward Face Layup
The shop temperature was 80deg F and the humidity was 30%.
Jason Piecowye, Maintenance Manager at Beyond Blue Aerospace, helped with the layup.
Dry micro was applied as required to low voids on the foam.
Micro slurry was applied over the entire foam piece.
2 plies of BID @ 45degrees was glassed onto the foam.
1 ply of UND horizontally above the leg cutouts was applied.
Peel ply, wax paper, and wood/weights were added.
Jason mixing the epoxy
Layers of fiberglass
Peel Ply over the layup
Cozy MKIV Home
Cozy MKIV Home
903
Chap 14: Centresecti
Chap 3 : Training
Chap 4 : Bulkheads
116
180
Chap 5: Fuselage Sid
79
128
Chapter 6: Fuselage
113
215
Chapter 7: Fuselage
Chapter 8
Other Cozy Projects
Training & Preparati
Training & Setup
