Beyond Blue
Date: 4-17-2010
Number of Hours: 1.00
Manual Reference: Chapter 3
Brief Description: Tools to improve quality
Sticky Stuff Dispenser:
The Sticky Stuff Dispenser is a practical engineering tool specially designed to eliminate the sticky, messy, costly hand proportioning of epoxy resins. A highly dependable, top-quality system, the Sticky Stuff Dispenser assures accurate measurement of resin and hardener. The Sticky Stuff Dispenser is a hand operated meter machine and can be adjusted to the volume ratio specified for the hardner being used. I purchased this one through Aircraft Spruce.
Wiss W20 10" Inlaid Heavy Duty Shears, Cut Length: 4 3/4" & Pizza Cutter:
For cutting the dry fiberglass cloth I use scissors and/or a pizza cutter. The Wiss W20 industrial fabric shears are lightweight, extremely sharp and comfortable. I purchased them via ALLBRANDS.com. The pizza cutter was purchased at Walmart.
Easy EZ Cutter EC1 Cordless Electric Scissors ( Dritz 28500, Consew EC110) Fabric Cloth Cutters, Lightweight Materials, Battery, Charger, 4.8V Adaptor:
I was having a tough time trimming the layups without displacing the fibers from the layup. These electric scissors are recommended for trimming the layups. These are ELECTRIC PIRANHAS with carbide insert jaws, wall transformer, charging base, dummy battery pack that allows you to plug in and cut if the battery is dead, and a second cutting head. I ordered it from ALLBRANDS.com. Wrap them up in a baggie and cover with masking tape to protect from epoxy, wipe off the jaws when you are done.
Wiss W20 Industrial Fabric Shears & Pizza Cutter
Easy Cutter Electric Scissors
