Brief Description: Right wing continuing TE repairs
A batch of epoxy was mixed and brushed onto the portion of the trailing edge where repairs are needed.
Flox was mixed and spread along the gap where the wing meets the trailing edge. One layer of bid cloth was applied and wetted out with epoxy. Shims (covered in plastic) were clamped above the glass and below the existing trailing edge to ensure the cloth wouldn't sag and would be flat.
Epoxy was injected into the recent inboard wing repair to fill any gaps around the foam.
