Removed the ailerons and checked against drawings to ensure all the rivets, screws, etc. were in place. Re-installed and inserted the 7 screws to hold the aileron in place on the wing and verified the gaps between the aileron and wing are ok. Fabricated an interface rod between the aileron and CS132 and adjusted it such that the control mechanisms were in the correct locations for the aileron neutral position and the aileron up positon stops at 20deg.
