Brief Description: Repair bottom of left winglet and wing trailing ed
Workshop temperature 23 deg C and humidity 62%.
Mixed a small batch of epoxy and poured a bit into other cups to make flox and micro.
Applied micro to the bottom of the damaged winglet to fill all void areas and micro'd foam in place. The foam was taped down while it cures.
Flox was applied to the inner trailing edge of the left wing on the bottom side ontop of the 2-ply bid repair already completed on the top side. The flox was covered with 2-ply bid, peel ply, and held flat and in place with a shim and clamps while it cures.
