Brief Description: Permanent install of left rudder hinges
I removed the rudder and hinges from the left winglet. Removed all clecos and the hinges from the rudder. I covered the centre and winglet side of the hinges with tape and mixed up a small batch of flox.
I applied a light layer of flox onto the inside of the rudder on the outboard wall where each hinge sits. I secured each hinge in place with pop rivets. Five rivets on the top and middle hinges and seven rivets on the bottom hinge.
