Workshop temperature was 24 deg C and humidity 28%.
A batch of epoxy was mixed up and used to make up some micro as well as a small cup of flox.
Epoxy was brushed onto the existing glass edges of the outboard bulkheads then micro was applied to both bulkheads.
Next, the edges were filled with flox to make flox corners.
One layer of BID cloth was placed on each outboard bulkhead at 45 deg orientation and wetted out with epoxy. Lastly, peel ply was added to both layups.
