Brief Description: Work on right elevator and stabilizer
Install and adjust trim servo rod. Fit trim servo cover and cut out openings. Install doors to tape for stripes and remove doors. Install attach tangs on right horizontal stabilizer and vertical fin. Burn openings in horizontal stabilizer for drain hole and attach points. Check balance on right elevator and order weight material.
